close
2nd sim
Trebor6864
Hi, I believe my Huawei P30 Pro is a dual sim, does thethe 2nd sim have to be on the EE network as that is the network in the card at the moment.
Regards
@Trebor6864  If the device was from EE then the device will be locked to EE and only a EE Sim card will work in the device if you’ve had the device longer than six months you can request it to be unlocked you can then use any network Sim card in the.
Click here to see how to request the unlock of your device this explains everything you need to know...
