iPhone 18 pro max
Mobster7890
Valued Contributor
Valued Contributor
I ordered Saturday for the iPhone 18 pro max and my order got confirmed Sunday. When I ordered it did say will get delivered on launch day. When should I expect an email for delivery details, if anyone knows please? Thanks
Gareth43
Problem solver
Problem solver
Download the DPD app using same info you used to sign up for the phone, DPD app most reliable way of knowing when phone is coming and plus it will give you the pin to give the driver more than likely
G Alston
iPhone 18 Pro Max
Thanks but I’m getting mine delivered to an EE store so let’s see but thanks anyways
Well that way then the store will most likely tell you once you can pick the phone up, or just ring store on release day and see if it’s there or not
G Alston
iPhone 18 Pro Max
