iPhone 18.1 beta dropping signal frequently
Treble
Has anybody else on 18.1 beta had there signal keep dropping in and out and does turning rcs off solve it thanks ?
32 REPLIES 32
@Robcrouch  The replies I gave basically says it’s not an EE issue and any developer would be looking at the Apple forums.    You also didn’t backup what said with my “daily device is operating normally”. As you claim this is only on a beta device,
I wish I could use big words like yourself but fortunately for you I’m a little more experienced with what should or shouldn’t be said within this forum.
Once again you seem to miss the whole point of the thread. Let’s try again… the op was asking if anyone else on ee had the problem.. nowhere has anyone suggested it’s not an apple beta issue. But narrowing down if it’s specific to just ee or other networks.
how difficult is that for you to understand? 😂
im still waiting for the answer as to what you actually came to contribute to the thread? Nothing it seems
Treble
 Beta 2 is out new modem and ee carrier hopefully sorts it
Gareth43
Problem solver
Problem solver
Been on new version of IOS 18.1 AI version and not had 1 disconnect in last hour where as before it was every 20 mins or so.
G Alston
iPhone 16 Pro Max
Treble
Yep all sorted now thanks some can put their handbags away now 😏😂
Yep!! Thanks 🙏 for that update I was going into circlers with the signals drops
I have betas before but this one was the worse
Carful guys the forum police will be along shortly if your not careful! How dare you mention your having problems with beta software:
and yes the update fixed the signal problem here too, thank god
indiannasingh71
I had the same issue and doing a network reset did. It solve the issue.
Advise is to revert back to iOS 17 and wait until official release is out.
Did not solve.
Treble
Beta 2 didn’t ? It solved everyone else’s
