iPhone 18.1 beta dropping signal frequently
Treble
Has anybody else on 18.1 beta had there signal keep dropping in and out and does turning rcs off solve it thanks ?
32 REPLIES 32
@Treble  It’s called a beta for a reason and you accept the issue that comes with beta software when you install it.      You could try a network reset on the device
Schockwave
@Treble , just to add, I have just installed IOS Beta 18.3, so maybe try updating to that one. I have not had that problem myself.
Treble
2 different betas my friend iOS 18 and iOS 18.1 with ai
Treble
Yes I know beta 2 should sort it and the modem
fw
Robcrouch
yes same issue, its terrible when imout, happens constantly. and no turning off RCS didnt help me
I  am on Beta 3, seems better, but that is why this is a beta version, so things may not work as required.
@Robcrouch  That’s why you don’t install beta firmware on your daily device. Not sure why anyone is asking on here as  it’s nothing to do with EE until you can rule out the beta firmware.  Perhaps you should be downgrading back to 17.     Oh just remember you can not reinstall any backup you might have from 18,  you need to have a 17 backup.     I do hope you have this if you decide to go back to 17.
Gareth43
Problem solver
Problem solver
Yeah I’m also on IOS beta 18.1 Ai version and I’m also constantly getting disconnects, reported to apple through the feedback app and there response was it’s working as it’s designed to. I accept the bugs and glitches with betas, so all we can do is soldier on now. Update to IOS 18.1 AI should be out in few days. Also turning RCS off doesn’t help as I’ve tried that. I’ve also tried a network reset and that didn’t do anything to help
G Alston
iPhone 17 Pro Max
Sorry where did I say it was on a daily device? Lots of assumptions made here…
yes we know it’s beta software captain obvious, did you have anything actually meaningful to contribute?
