15-11-2020 07:51 AM
my phone only rings 3 times before voicemail kicks in. How do I make it ring longer?
15-11-2020 11:04 AM
Try changing ringing length;
**61*07953222222*11*30# press call
The 30 at the end is the seconds your device will ring for before it goes the voicemail you can change this in 5s. The max is 30 and I believe the minimum is 5
15-11-2020 11:04 AM
15-11-2020 11:34 AM
Thank you Chris_B
I have set it up using the solution you have gave me.
I’ll ignore my next call to see if it works. 😂
Jacks81
