Sim not working Iphone 15 Pro Max
0wen
Just upgraded my iPhone from 14 Plus to a 15 Pro max and I've transferred everything over and my sim wont work?
I don't get any signal but the phone accepts the sim as my number is shown when I check I've already tried reinserting the sim several times and also resetting my phone any help would be greatly appreciated.
10 REPLIES 10
Northerner
H I @0wen
Where did you get the iPhone.
Are you in the UK.
Yeah from the UK 🙂
Peter_W
Hey @0wen!
Welcome to the EE Community 😊
If you haven't already, can you please try giving your network settings a reset?
This won't affect any of the personal data on your phone, but any WiFi networks will need you to enter the password next time you connect.
Peter
Hi Peter, I’ve already tried this and it didn’t work 😞
I tried it again and it didn’t work it asks me for a pin to unlock my sim and I put in 1111 and it unlocks but nothing happens still no signal
Peter_W
Thanks for giving that a try @0wen.
If you pop this SIM in a different handset such as your previous iPhone, is this still working?
Peter
No it no longer works in the old one either
Peter_W
Cheers @0wen, it definitely sounds like something isn't quite right with this SIM, but we'll absolutely be able to get this sorted for you.
If you've got another phone you can contact us from, you can get in touch with our technical support team where they can run some further checks and if needs be order you a replacement.
Alternatively, you can also pop into one of our retail stores and get an immediate replacement free of charge.
You just need to provide photo ID with either a valid passport, or UK driving license.
Peter
Okay no worries I’ll just pop in store many thanks appreciate the help
