on 21-01-2023 09:47 AM
For a very long time now I have been unable to send SMS messages - I have checked all settings, can send iMessages, etc and do everything else. I have tried checking my message centre number but cannot find it, and when typing in the # number found on website searches it just says error…
i really need this fixed for work so any help appreciated
on 21-01-2023 11:50 AM
Hi @Samreed23,
Are you able to make calls and use mobile data?
Are you using a pay as you go or pay monthly plan?
on 21-01-2023 12:13 PM
Hi
Everything else works fine, I can call, use data etc. I’m on pay monthly
thank you
on 21-01-2023 12:36 PM
Hi @Samreed23,
Please get in touch with Customer Care so a member of the team can make sure everything is setup correctly on your account.
They'll be happy to help. 🙂
on 08-07-2023 08:18 PM
And you can't do it here, write settings with numbers, etc. Only suggest contacting support where you have to wait a long time?
on 14-07-2023 01:37 PM
Hi @RobertM75 , might be related if you are using an eSIM, see my post with my recent experience: https://community.ee.co.uk/t5/SIM-cards-Porting/eSIM-frustration-went-back-to-physical-SIM-after-1-d...
Hope it helps
