My iPhone will no longer stay connected to my Wi-Fi
kevdunk
9 REPLIES 9
WiFi is just a connection to some router which is no concern of EE's unless the router is theirs too,
Leanne_T
Morning @kevdunk
Thanks for coming here 🙂
Have you tried restarting the router and iPhone?
Do you have any other devices connected to the router?
Thanks.
Thanks Leanne,I have restarted both several times.Other devices are working fine.Kevin
Sent from Yahoo Mail for iPad
Leanne_T
Thanks @kevdunk
Can you connect your iPhone to any other WiFi network and stay connected?
Leanne
Northerner
Hi @kevdunk
Turn off wifi calling if you have the service activated. If your signal is strong then the iphone will drop off wifi.
Thanks,Don’t fully understand your suggestion.Turned off Wi-Fi calling, not in a strong signal area.No difference noticed.Kevin.
Leanne_T
Hi @kevdunk
Can you try resetting the network settings on your iPhone, to do this go into Settings > General > Reset > Reset Network Settings. This will remove all saved WiFi passwords.
Can you try and connect again, does this work for you?
Thanks Leanne,Just tried that, no difference unfortunately.Kevin.
Leanne_T
Thanks for trying @kevdunk
Can you stay connected to any other WiFi network?
