Iphone 17 Pro Max screen
Haider101
I’m having an issue with a brand new Iphone 17 pro max. Literally out of the box a few days ago… the screen i can only describe as ‘sticky’ when gliding the finger or thumb more noticeably up down but generally any direction.
Has anyone else had this issue or similar? It is particularly noticeable when playing games and swiping left right the glide is just not the same as previous iphones. Have tried cleaning with micro fibre cloth etc (which you should not have to) but still the issue persists.
Ritu_D
Goo morning @Haider101
Thanks for reaching out here on the community.
This is a very strange one, I have definitely not come across this one before.
I would recommend Contacting Us so one of our guides can take a look into this for you.
Ritu
Ritu_D
Ritu
Haider101
Thanks for the message, yes I would like to contact someone about this. It must be a faulty device then as I have been patient but this screen but it is just not as responsive as older iPhones
Katie_J
Hi @Haider101.
To get in touch with our technical care team please click the link provided by @Ritu_D.
This will take you to our contact page with ways to contact us.
Katie
