14-01-2022 03:06 PM
I need to access the old handset info on my iPhone 11. How many gb the handset is
14-01-2022 03:15 PM
The Device Storage settings should tell you that.
14-01-2022 03:16 PM
Hi @Juglover
Use another phone camera or magnifying glass (if you need to) and look at the text on the back near the bottom. I'm sure it tells you in that info.
14-01-2022 10:42 PM
Go into Settings/General and then select About.
You should be able to see further down "Capacity". This will tell you the GB size of your iPhone.
