on 22-06-2025 02:25 PM
Myself and partner both have an iPhone 14, my partner can turn mobile data on and off from the Home Screen. When I try to do it I can turn it on from the home screen but to turn it off I have to go into the settings in the mobile data and turn it off there. Does anybody know why this is or how to resolve it. Not a major issue I know but it’s annoying me !
Solved! Go to Solution.
on 23-06-2025 06:18 PM
@Belburn78 After following @Lesley_W advice, highly recommended you give this ago, ( you can even put the same cellular data toggle on there twice to test with )
you have 2 options wait till iOS 18.6 is pushed out to see if this resolves the issue or try a factory restore. Don’t forget to backup the device if you do this so you can then restore from that backup
iOS 18.6 beta 1 was pushed out 6 days ago so it’ll be awhile yet before it’s available.
on 22-06-2025 02:51 PM
Hi @Belburn78
Swipe down - Quick settings - hold down on the WiFi icon.
He might have an appointment installed or just ask him.
on 22-06-2025 03:46 PM
Hey there @Belburn78!
Thanks for stopping by 😊
You could possibly be on different iOS versions causing the discrepancy, or it is possible to customise the layout of the control centre.
On iOS 18.5, if you swipe down from the top-right it should display the default control centre, and this has the option for WiFi as standard but not mobile data.
If you then select the small icon at the right side of the screen that looks like a mast with radio waves, it'll take you to the dedicated page for your connections.
Apple have more details on how this all works in their help guide here.
Peter
on 23-06-2025 12:08 AM
on 23-06-2025 09:07 AM
Good morning @Belburn78
Thanks for explaining what is happening.
That does seem strange you can turn it on but not back off, is your phone on the latest software?
Ritu
on 23-06-2025 01:33 PM
on 23-06-2025 06:02 PM
Thanks for confirming that @Belburn78
Have you ever tried removing and re-adding them in the control panel to see if that makes a difference?
Lesley
on 23-06-2025 06:27 PM
on 23-06-2025 06:28 PM
@Belburn78 What solved it ? It will help any else if they see this and have the same issue.
