Battery Problems with iPhone 13
Jackiekruse1309
Hi I’ve got an I’ve got an iPhone 13 which upgraded with EE 11 months ago. About a week ago the battery started draining really quickly for no reason. Even if I hardly use it if on 100% in the morning by about 5.00 it’s down to 15%. The battery settings say it’s running at 95% of its original state. I’ve got half my storage left and I’ve deleted a load of apps. What’s happening? Any ideas?
@Jackiekruse1309   Click on setting>battery and see if anything stands out that has a high battery usage.
 Have you installed any new apps ?  If you have yet delete
You might need to do a factory reset.
