25-10-2020 07:33 PM
I have noticed since upgrading to iPhone 12 pro 5G the data usage is incorrect and the EE App shows I am using more data than I actually am.
I have been monitoring with a third party app and it’s defiantly wrong.
has anyone noticed this ?
25-10-2020 09:21 PM
@Rtorrez88 Sorry to say but the 3rd party app isn’t connected to your EE account that monitors your data usage. The app your using will not be 100% correct and is a guide only. What app is it ?
25-10-2020 09:27 PM
25-10-2020 09:34 PM - edited 25-10-2020 09:37 PM
@Rtorrez88 if I’m looking at the correct app and I believe I am that app hasn’t been updated for two years so I wouldn’t say it’s fully compatible with iOS 14 or your new device or even 5G. You need to go by what your EE account says you can even use THIS
