Where are the QR scans stored on my phone?
NorthTower
After I have saved the scan, the storage location is flashed too fast for me to read it - so I can't find where the code is stored?
Matt_124
What is the QR Code supposed to be linked to or what is it's purpose? Knowing this would make it easier to find.
If it is a file, it would be located in the Files on your device. If it is for a Web page it should open this for you. If it is for a WiFi Network, it should connect you to it.
Most devices have a recent section in their relevant Files app or the ability to sort by Date.
Northerner
Hi @NorthTower
If you took a screenshot then it will be in your gallery.
A QR code is often (but not always) just a shortcut to a weblink. In which case, the weblink should be in your browser history.
If you're using your phone's inbuilt camera function to photograph the QR code, it may have a history function. I sometimes use a specific QR-reader app that I've just got used to over the years - it has an in-built history function, but yours may vary.
