28-10-2024 05:51 PM
Hi Have a Galaxy Tab s6 ( not Lite) with a screen that doesnt function - as best I can tell the tablet turns on I get haptic feedback on contact and vibrations when I plug it in but have no way of knowing if it still properly funtioning and whether worth fixing - the screen is black at all times and ther is no visible damage to it... any suggestions?
29-10-2024 08:24 AM
Thanks for trying @DinoK
If this has not worked, if you get in touch with our tech guides they can run through some troubleshooting with you and let you know what is needed.
We also have an online diagnostic tool on our What Should I Do if I Have a Problem with My Device? page.
Hope this helps 🙂
29-10-2024 08:17 AM
Morning @DinoK
Thanks for coming here 🙂
Could you try the steps in the Blank or black display on a Samsung phone or tablet Help page to see if this helps?
If the screen doesn't come back after trying this, how long have you had the tablet?
Speak soon.
29-10-2024 08:20 AM
29-10-2024 08:24 AM
Hope this helps 🙂
