Puk code
Roseandjoe
Puk code
You'll find the PUK, to unblock your SIM after too many incorrect PIN attempts, in your online MyEE under Menu > Account Settings > Unlock your SIM.
7 REPLIES 7
Hi
There is no Menu option in My EE. The app also doesn't work at the moment. Any workaround?
Leanne_T
Hi @bbob90
Thanks for coming here.
Could you try these steps to locate the PUK, please log in using this link My Account (ee.co.uk)  > Manage your SIM/eSIM, this will show under unlock your phone.
Or, if you select Home > Plans and Subscriptions > Phones and Devices > eSIM/SIM replace > select cancel and the PUK will show.
Alex_M
Star Contributor
Star Contributor
Hi @bbob90,
You can get your PUK code on the right-hand side of this page.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
Yes, that worked! Thank you
Thanks!
Leanne_T
Thanks for letting us know @bbob90
Leanne 🙂
