21-01-2022 02:47 PM
My phone has beeping on the line and sound cuts out but only in the house. WhatsApp, reading and searching on Internet screen is reloading and jumping about. Out of the house everything is fine. What is the problem?
21-01-2022 07:08 PM
Hi thanks, finally sorted it, my Bluetooth constantly trying to connect when it shouldn't. Turned it off and all fine now Have to try a reset according to EE. Think it was an auto update this week thats done it.
21-01-2022 03:08 PM - edited 21-01-2022 03:09 PM
Hi @Jan80 ,
Do you see the same thing when you turn WiFi OFF, and turn mobile data ON?
How about WiFi ON and mobile data OFF?
21-01-2022 06:10 PM
@Jan80 Is that on cellular data or when connected to Wi-Fi? When your out about and your on cellular data but if your on Wi-Fi when at home the issue is related to that connection and not cellular data.
Have you tried restarting the device?
are you using Wi-Fi calling when at home ?
21-01-2022 07:08 PM
