23-08-2026 01:06 AM
First time poster
My nothing 3a is not getting any updates through. The OS is probably 18 months out of date and it's now starting to cause issues with apps
Any suggestions for sorting it
23-08-2026 09:51 AM
Hi @Asmith1708,
Welcome to the EE Community
Are the updates just not showing when you try and scan for an update in Settings > System > System Updates, or are they showing but you are getting some kind of error when trying to download and install?
Is there anything specific you have tried already? One common thing to first try would be clearing the cache of your download manager and google play services and restarting the phone then scanning for updates. Does your phone have plenty of storage space available?
Alex
23-08-2026 10:00 AM
Hi Alex
This is the update status. Been through and cleared the cache.
Storage, got around 30gb available. It's made no difference had more available a
23-08-2026 10:13 AM
@Asmith1708 Have you tried a full factory reset of the phone, as if something has become corrupted with the software to prevent updates, setting it back to default and testing if it finds updates then would be worth trying. How long ago was it you bought the phone?
Alex
23-08-2026 10:16 AM
Hi Alex
Bought it around April/ May last year (not long after launch), from the EE online store.
I've already tried a full factory reset and it doesn't make a difference.
23-08-2026 10:38 AM
@Asmith1708 It sounds like realistically you have tried all that would be possible from the phone itself to get it to update then and to get it sorted the best option is to probably get it sent away for a repair for a technician to take a look.
Either using Nothing directly or our repair service, their website advises a 24 month warranty so as long as the phone isnt damaged or anything you should be covered for an in warranty repair.
Alex
23-08-2026 06:12 PM
Hi Alex
I've contacted Nothing and awaiting a response.
Sent over the details I've posted here and a few more bits
24-08-2026 08:30 AM
@Asmith1708
That's great. Please keep us updated with how you get on.
Ali
24-08-2026 04:50 PM
Hi Ali
Had a response from Nothing with a few check throughs (available storage, critical updates via play store, battery etc...). Had done them all and have tried with the device fully wiped before asking for help.
Been advised to book in for a tech to look at it. Which I have done with EE
12-11-2026 10:35 AM
I have the same phone and same issue. I contacted Nothing Support who sent me instructions for manually updating to the latest Nothing OS which includes the latest Android version. Downloading the update package is a real pain as it comes in a zip file which my phone didn't recognise. I had to wait for the download to fail then force a download via the browser. After that, the instructions that Nothing had sent didn't resemble the steps on the screen so I had to improvise. Eventually the upgrade was successful however, I upgraded in two tranches; first to NOS 4.1 then to 5.0. During the process, I discovered that the issue is caused because our phones aren't registered for the NOS BETA upgrade programme.
