App Captcha Issues
JD638
Does anyone know why I can't get past the Google Captcha on the App - can't enter any comps - I've deleted and reinstalled the app and it's the same & restarted my mobile. The QR code on EE's page takes you to Apple App store (?) but doesn't give an option to install. My husbands works fine it's just mine! Thank you  EE.jpg
Northerner
Hi @JD638
Are you using a VPN or ad blocking software.
Also try clearing your cache.
Thanks,
I've no idea but I'll google it and have a look - thanks for your quick response 🙂
