Using App to record Sky Sports?
Tog_PD
I am new to EE TV having switched from Sky Q, I can see how I can set up to record TNT Sports in the EE App on my phone when away from home, but how do I do this for Sky Sports?
I have paired my mobile app with the Pro box. I have a subscription to Big Sports and Now Entertainment, plus HD Boost. All channels are working ok, I am just trying to work out how to remotely set up a Sky Sports recording when away from home - thanks in advance for any answers 🙂
zulu17
Scholarly Contributor
@Tog_PD
  • Open  EE TV app on your mobile.
  • Select LIVE
  • Select SCHEDULE
  • Scroll Down and across in the schedule and select programme you want to record
Within the mobile EE TV app if you select  MYTV then select RECORDINGS  you will see the recording  appear under SCHEDULED once the request has reached the box  and. HISTORY  of the requests made.
The mobile and TV box are not directly connected , ie the request/data go via YOUVIEW/EETV hence there will be a short time lag.
zulu17
@Tog_PD
  • Select LIVE
  • Select SCHEDULE
Thanks, that's solved it, I was not looking at the schedule - thanks very much 🙂
