Update apps
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2024 06:45 PM
On my EE TV settings, into software information and then Update apps, keep getting a message only recently saying We can’t update your Apps please try again later or visit bt.com/tverrors for help, but it does not give me any help whatsoever as it ask for a error code and there ain’t one and it’s been like this for a few weeks now, can someone tell me what too do please.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2024 08:12 PM
Hi @KJMcElroy42
Are you prompted to update the app or is this something you are checking for without any prompt.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2024 08:12 PM
Hi @KJMcElroy42
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2024 10:02 PM
this something i am checking for without any prompt.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-05-2024 09:44 AM
The "Update apps" button doesn't actually do anything (except occasionally show an error for some people), and we have a long standing request with YouView to remove it. Please ignore the error you're seeing - your apps are already up to date.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-07-2024 04:23 PM
I have had similar msg too. However, I was prompted to go to the update software/apps button because I had received a pop-up on screen advising that some apps needed updating! Do they actually need updating and if so, how do I go about it as the update button does nothing? Thanks in advance.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-07-2024 04:32 PM
Could I ask you to please launch the EE TV app on your TV Box Pro @Ted1959 - this will cause it to send us some logs, and will enable me to see if there's anything that needs to be fixed.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-07-2024 04:33 PM - edited 16-07-2024 04:33 PM
YouView boxes don’t do that, but my internet-connected LG C2 does, as do many smart TVs.
Have you got a smart TV, with the YouView box plugged into it, and is it possible the message came from the TV, not the YouView box, about apps on the TV?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-07-2024 04:43 PM
Sure, just have done so. Do I need to leave the app open while you check?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-07-2024 04:48 PM
No need, thanks @Ted1959 - your box is reporting everything present and correct. No updates required.
Could it be that it was your TV, as @Midnight_Voice suggests? Maybe you could take a photo if you see the message again?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
16-07-2024 04:56 PM
Thanks for that. I can’t find any reference to updating apps in my tv settings, I suspect I will be prompted to update individual apps as I try and open them!
- link broadband to ee app in Broadband & Landline
- Failed delivery but no new updates for delivery? in Mobile Broadband
- Broadband bill on app shows my bill as £71.61 should only be £32.99 be in Broadband & Landline
- Microsoft Teams Quality Issue in Broadband & Landline
- I have a heat pump and use the ONECTA app. in Broadband & Landline
