on 02-05-2025 10:23 AM
Hi
When I press the EE start up button on my remote the blue lite flickers on the box for around 2mins before the tv comes on, what do I need to do to rectify the problem?
Les
Solved! Go to Solution.
on 02-05-2025 04:39 PM
@Ibartdeco51 I'm not so sure about that last one 😉
There's definitely a chance with the others though - in general if you've paired your EE TV remote to work with your TV set as well as the EE TV box, a quick press will just power off / on the box, whilst a long press will do this for both.
If you haven't already, I'd try doing a reset on your box; if you go for the 'light' option listed on our help page here, it won't affect your recordings too.
Peter
on 02-05-2025 02:11 PM
Hey there @Ibartdeco51 😊
When you're pressing the button on your remote, is your TV set already on and just displaying no signal until the 2 minutes have passed?
Also does this happen every time you boot it up, or is it intermittent?
Peter
on 02-05-2025 04:30 PM
Peter
