Resuming a paused program to resume in another room.
Wedgie1
Is it possible to pause program on the mini to then resume in another room on the main box?
Christopher_G
Hi @Wedgie1
@Chris_B is correct. You can't resume a paused programme on the Mini Box that you've been watching on your main box.
The TV remote would work on both devices, so it could be that the boxes are both in-range of the TV remote.
10 REPLIES 10
@Wedgie1  No, it’s not possible.  The boxes are not linked like that in fact there not linked at all
That cannot be true as when I switch on the TV and minibox in my kitchen the TV in the other room switches on!!
Wedgie1
Just getting started with EE TV , when I switch on the TV/ Mini box in the kitchen, the main TV attached to the main EE box in another room switches on to, guess its the bluetooth remote any suggestions?
Leanne_T
Hi there @Wedgie1
Thanks for coming to the community 🙂
Are you using the EE TV remote?
When the TV in the other room turns on, does the programme play that you currently have on the other TV?
Speak soon.
Leanne, no the program is different to the one playing on the mini.
Yes using the EE remote.
Christopher_G
Hi @Wedgie1
Sounds logical , but could be a bit if a pain, being to wonder if the mini box is worth spending £10 a month on given its limited capabilities.
@Wedgie1 as far as I am aware of the first mini box of was free for multiroom or has that now ended?
I agree there are some limitations but hopefully some of those gaps can be filled in future.
EE Pro TV box, Full Fibre 900
For EE contact details see
https://ee.co.uk/help/contact-ee
