Pro box
Profile closed
Not applicable
 if l got 2nd pro box ee from Amazon will 2nd pro ee box work with fibre 1.6Gbps broadband if 2 boxes with link to the same broadband
Profile closed
Not applicable
You need to have signed up for Extra Box if you want to use 2 boxes on your account, but you can swap the supplied non-recording version for an EE TV Box Pro that you have obtained elsewhere.
Caveats:
  • EE TV hardware is supposed to be returned at the end of a contract and isn’t anyone’s to sell
  • EE could block the box at any time from working (they haven’t so far)
  • If you try and add more than 1 box to your broadband without setting up Extra Box, it will ask you if it is the “main box” as there are “too many boxes on your broadband”
  • If you say yes, the first box will stop working (hence why you need Extra Box)
  • The maximum number of boxes you can have is 3, no matter how fast your broadband is
Midnight_Voice
@Profile closed @Profile closed
I am usefully informed that if you set a recording on a main box, and then switch away from it to another box as main, the recording will nevertheless be made.
You just won’t be able to watch it unless you switch that box back to being main again 😛
Profile closed
Not applicable
Broadband is set for a extra ee tv box l got a ee tv mini box but l to record my own channels so l watch them later or another day
So because the broadband is set for 2 boxes could l have an ee tv pro box the broadband is a smart hub plus
Matt_124
Just to add to the thread as no-one has yet mentioned this: EETV is currently NOT available on Full Fibre 1.6Gb Busiest Home Bundle or Made For Gamers packages.
Profile closed
Not applicable
Well, that is important information which makes any potential solutions irrelevant! 🤣
