03-09-2025 07:59 PM
My EE remote will not connect to the TV.
I've done the home+7 and +9 option.
I've reset everything, unplugged everything.
It's set up for TV and not Top Box.
I can't control TV volume or change TV input source
10-09-2025 07:09 AM
Could you please check that screen again - the firmware on your remote showed as being on v2.001 which is a little out of date. I'm hoping it will have updated by now.
10-09-2025 08:01 PM
Nope, still showing as v2.001.
11-09-2025 01:04 PM
I've just been informed that there are 2 versions of the EE TV remote - there's a different chipset inside. v2.001 is the latest version for the other chipset to the remote I have.
The way to confirm that it's definitely the latest is to launch any app on the TV Box, and then hold down the back button on the remote. If the app quits, it's already running the latest version.
11-09-2025 08:28 PM
Yep did that and worked out for the latest version
Still can't get it to connect to TV though, currently have 2 remotes on the go 😞
1 to turn TV on/off and adjust the volume
EE remote to change channels or apps
12-09-2025 12:42 PM
I think that the TV on/off is an HDMI-CEC function. It might be turned off on your TV. Look in the TV settings to check that is turned on. The TV doesn't come on immediately with the box. You need to wait a few seconds for it to switch.
The TV volume adjustment is done by the box remote's IR function. You can check whether yours is working by pressing the volume up or down button while pointing it at a smartphone camera.
12-09-2025 12:55 PM
Its the old Virgin remote which worked perfectly 😉 as that was set up as HDMI-CEC etc to only have 1 remote lol, so I know it works fine. Just can't get the EE to configure yet, appreciate the input 🙂
12-09-2025 07:54 PM
Thank you.
CEC should work whether the remote is paired or not. Something strange is going on.
17-09-2025 05:39 PM
Any other suggestions?
18-09-2025 07:35 AM
I can't remember how I managed to find your account last time, but I can't find it again. Can you please send me an email at eetvsupport@ee.co.uk with your account number, and I'll see if I can get any more information.
