EEBox does not always connect to EE Router
RichardBD
I have just migrated from BT to EE and got the latest Router and EE TV Box.    The box frequently has problems connecting to the router over Cat5e ethernet.  I get a who string of different error codes but they all basically go back to "check your wired connection to the router and reboot the router and TV box".   I have done this a number of times but have not made any progress.  I know that the ethernet connection is OK as the previous BT TV box is working fine in accessing apps such as iPlayer, yet when I swap the cable to the EE Box it fails to connect.     Somethimes the EE Box will manage to connect after an hour or so.    Is this a problem with the EE Box or the backend EE Service that the EE Box connects to?
Crucially what I can I do to improve the situation.  In the meantime I will continue to use the existing BT Box even though it is painfully slow.
Christopher_G
Hi @RichardBD
Welcome to the community.
I'm sure you've already tried this, but could you try a different ethernet port on the router? I know it works on the BT box, but is it possible to try a different cable, just to eliminate that completely as a potential issue?
If all else fails, I recommend speaking with our customer support team, so they can run some tests on our end.
Northerner
Hi @RichardBD
Which EE box/router do you have.
RichardBD
The router model is : mart Hub SH35A
The EE TV Pro is : RTIW387
Last check for software updates wss today.
Richsrd
Christopher_G
Hi @RichardBD
