EE tv box
robh661
I’m being offered the opportunity to add EE tv to my package, I was reading up on it, and is says I can plug a normal aerial in, the question is, does the box has a pass through port, so I can attach  another aerial lead from the box to the aerial socket on the TV, or is it HDMI only.
DarrenDev
EE Product Expert
The TV Box Pro does have pass through available - you'll need to go into TV Settings and turn it on when you set the box up (it defaults to off to save power).
Please note that the pass through does NOT include the EE TV experience - i.e. it only passes the Freeview signal through.  The TV Box Pro interface is only available via HDMI.
DarrenDev
EE Product Expert
robh661
Thanks @DarrenDev that helps a lot. 👍
I'm having massive problems with the TV  ee box stuttering tv picture losing freeveiw channels losing recorded programmes. Basically it is useless
@Carronvalley1
That’s quite a parcel of issues; none of them unknown, but all of them together is not typical,.
So you need to get in touch with EETV by telephone support to see what the resolutions might be, as there’s no single fix that occurs to me, unless you have a rogue EETV box. And even that, they will have to deal with for you.
