EE TV Box buffering/freezing
CBoasty
we just signed up to the EE TV full works package and even had an engineer come out last Friday to check our connection and setup. He checked it and we get 150mbps download speed and he said it should be more than enough to get good tv through the wifi.
since he left all we’ve had is all of the apps freeze, tv pretty much unwatchable through the EE TV box. We switch to our smart tv and can watch now tv, Netflix etc with no problems whatsoever… but through the EE Boxes cannot watch anything without the picture breaking up and freezing. This happens to both the pro box and mini box. I have done resets, reset the internet multiple times and this does not help. I even have a wifi extender/repeater setup to see if that mitigates the problem with no success. I have read plenty of posts experiencing similar. It’s frustrating as we just left sky q and didn’t have any issues and we are already debating going back to sky as we are within the cooling off period. Is there any advice on what we can do? Or anyone experiencing similar? Is it the boxes?
36 REPLIES 36
We are still experiencing buffering and freezing, dispite being connected via Ethernet, much worse at night….. we have now been sent a powerline network extender to replace the old BT one which they have now decided might be the issue.  Not sure if you are using an old BT power extender for the Ethernet cable.  I am going to connect it up later, hoping this rectifies the issue with the new EE box things, but it has taken 4 weeks to get to this point 🙈
our billing issues have finally been sorted…….
Do you have the problem when just watching recordings or is it streaming things from online?
Lowie
It’s streaming and watching live TV,we get errors saying we need to add BBC 1 to our subscription, then it says we have no internet, when we do as the kids are watching something fine next door on a smart TV…. I have not recorded anything, but suspect it would buffer,  freeze, and drop out as that what is happening when we watch live TV.
Jobba
Hi
Not sure if you managed to sort the freezing problem, but I had the same issue when I moved from BT to EE. However after a while I noticed that the freezing seemed to happened if I we had the washing machine or dishwasher on and also when a light switch was turned on. This lead me to think of potential electrical surges to the EE box which may be causing the freezes. I checked the power cable into the EE box and noticed that there was no surge protector on the power cable. I have since purchased a surge protector socket and plugged my EE box via this. Its early days as I have only had it plugged in for a few days without any freezing. However bearing in mind it did it multiple times every day, it may be worth you trying this. It cost me £10 on ebay for a three way surge protector socket.
Good Luck
Mrssteven
It is most definitely a problem with the EE box. I watched sky sports through eetv and the picture freezes regularly. I immediately changed to watching a whole game through Now TV and it was perfect. I switched back to eetv following the game to watch the after match discussions and it jumped regularly again. It’s most definitely a eetv problem. It does not freeze on any other channel other than sky sports through ee. If I can watch a game on Now TV or a game on any other channel and it doesn’t freeze but freezes while watching on eetv Sky sports it’s a problem with eetv so it can’t be a internet speed or connectivity problem
  • It is most definitely a problem with the EE box. I watched sky sports through eetv and the picture freezes regularly. I immediately changed to watching a whole game through Now TV and it was perfect. I switched back to eetv following the game to watch the after match discussions and it jumped regularly again. It’s most definitely a eetv problem. It does not freeze on any other channel other than sky sports through ee. If I can watch a game on Now TV or a game on any other channel and it doesn’t freeze but freezes while watching on eetv Sky sports it’s a problem with eetv so it can’t be a internet speed or connectivity problem
Peter_W
Thanks for explaining this for us @Mrssteven.
Just as a heads up, you can tag multiple users with @ in your replies so you don't have to send multiple identical responses 🙂
How is it your box is connected, and have you had the chance to reach out to our technical team about these issues?
Peter
Mangocat
I have the same issues as described in this thread.   I'm new to EE fibre broadband and tv.  The tv service has never worked properly.  If I connect the tv box to the wifi extender/booster via an ethernet cable the picture buffers/'pixelates'.  If I connect the tv box to the tp-link Passthrough Powerline Network Extender via an ethernet cable the picture freezes and then error code IPC6023 appears on the screen.  It's happening every 5 to 10 minutes, and as another user has suggested, it's worst at night.  EE tv is now basically unwatchable.  A technician attended earlier this week and said there's nothing wrong with my set up.  Has anyone else managed to resolve this issue?  Whilst the EE customer service people are very nice, I've had this issue ever since I joined EE a few months ago.  It's frustrating paying for a service that doesn't seem to be fit for purpose.
Leanne_T
Hi @Mangocat
If the engineer could not find any problems when they have visited, please get back in touch with our broadband tech guides and they will continue the troubleshooting to help you get this sorted.
Thanks.
