EE TV Box buffering/freezing
CBoasty
we just signed up to the EE TV full works package and even had an engineer come out last Friday to check our connection and setup. He checked it and we get 150mbps download speed and he said it should be more than enough to get good tv through the wifi.
since he left all we’ve had is all of the apps freeze, tv pretty much unwatchable through the EE TV box. We switch to our smart tv and can watch now tv, Netflix etc with no problems whatsoever… but through the EE Boxes cannot watch anything without the picture breaking up and freezing. This happens to both the pro box and mini box. I have done resets, reset the internet multiple times and this does not help. I even have a wifi extender/repeater setup to see if that mitigates the problem with no success. I have read plenty of posts experiencing similar. It’s frustrating as we just left sky q and didn’t have any issues and we are already debating going back to sky as we are within the cooling off period. Is there any advice on what we can do? Or anyone experiencing similar? Is it the boxes?
65 REPLIES 65
paulfirestarter
We have just signed up for EE TV pro too and have the very same issues as you mentioned. Watching itv1 and poctur and sound keeps freezing and distracting from trying to watch the movie.
Why doesn't anything work anymore without so many teething problems.
Should have chosen apple TV
rdc384
Get them to change it
Regards, Richard
John_RED5
Yup my box freezes as well this company needs to sort out it's software or everyone will go elsewhere i will soon it's crap
paulfirestarter
Hi John I have recently had the EE pro TV box and had similar issues with freezing etc.
Try this:
Go into home and select picture and sound. Change hdmi frame rate matching to off. Set the hdmi sound to surround as this was set to stereo only and sound was awful before I changed this and sound much better now. Change hdmi display to other settings and give it a go.
Hope this helps but EE are awful with support now for some reason.
Regards Paul
Liam__1993
Ive been having the same problem for a week or so now and have followed every step that EE advise. Its not just with the on demand or recordings either its with live tv too.
Granted I have the tv through WiFi and never had any problems at first with it, but the past week or so its been an issue.
@Liam__1993 I can confirm that the statistics on your line are bad, and also bad for a few of your neighbours, but not everyone - it doesn't currently map to any known issues, so we're unsure of the cause.  It is being raised for further investigation.
