5g smart hub
Triquet
I have a 5G Smart Hub, which works pretty well, both with computers and VOIP through an adapter. I have just bought a Bush television, but I simplay can't make it connect to the internet. The television finds the correct Hub Newtwork name, and I have tried the WiFi password many times but it just won't connect. It seems to try and then disconnects.
I have tried getting in using the admin IP 192.168.1.254 but that doesn't work either.
Northerner
Hi @Triquet
Try it, try to avoid the 5.0 channel.
Northerner
Hi @Triquet
Which model bush TV do you have.
It sounds like a comparability issue are you to the 2.4 channel.
It's a small Bush 24HT25CB.
When hunting for Networks it shows both the 5.0 GHz and one without a
number on the end which I assume must be the 2.4 GHz?
Cheers
Triquet
Northerner
Hi @Triquet
Finally got it going on 2.4 GHz and it's looking pretty stable. So
that's coming to me via 5G. It's all magic when it's working
That's for a fixed EE Home BB router. For an EE mobile router use 192.168.1.1
