28-03-2026 08:43 AM
Anyone else having issues in the Wetherby area, had no service or broadband since yesterday morning
28-03-2026 09:26 AM
Regarding the mobile side... If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
28-03-2026 11:52 AM
Not my phone, it’s my sim router that was down. It now up and running after a reset svd full power off reboot
28-03-2026 12:11 PM
A mobile router should have the same access as a mobile phone. They both use a SIM to connect to the EE mobile network.
