25-04-2024 12:53 PM
I am currently on holiday in Mexico we arrived Sunday and I have not received no phone calls or messages I am a self employed hairdresser and worried that I am loosing business. I have text my daughter and watts ap my son but nothing else
any suggestions please
25-04-2024 01:12 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
25-04-2024 01:18 PM
@Hairtogo wrote:
I am currently in Mexico and I have not received no phone calls or message
Does your phone show coverage of any Mexican networks? Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
