iMessage number not correct
Aaron155
Hi all
i have recently joined EE and ported my number from Three.
I have noticed that on my iMessage and FaceTime settings my number is incorrect. I assume it is the number EE gave me before my Three number was ported.
When I add my correct number it then lists it, but tells me that iMessage and FaceTime can’t be used with this number?
Any help appreciated.
@Aaron155  Turn off iMessage and FaceTime then restart the device. Now in Settings phone make sure your number is correct if it is you can turn iMessage and FaceTime back on.
Just tried, didn’t work unfortunately.
Katie_J
Thanks for trying @Aaron155.
If you follow these steps does your correct number show?
Settings > Tap your name > Scroll down and tap your iPhone > then you will see your number.
Katie
Hi Katie
No, it shows the wrong number in there, assume it’s the original EE number before mine was ported.
Katie_J
Thanks for checking @Aaron155.
If you are unable to update this, please give us a call.
Katie
