30-03-2022 11:18 PM
I asked EE to transfer a PAYG number to a PAYM SIM and although the number has gone across successfully, everywhere else on my phone and on my contact card it is still displaying the number that came with the SIM.
I have tried to update the number in SIM card settings but it won't update elsewhere.
I have a Samsung A52.
Any ideas?
31-03-2022 10:04 AM
Morning @Karaokequeen
Thanks for coming back here.
If you give us a call on 150, our customer care team will get this looked into for you.
Let us know how you get on 🙂
30-03-2022 11:27 PM
If calls & texts are working successfully on the new number, that's the important thing.
What specific menu options on your phone are causing concern?
30-03-2022 11:45 PM
Good question you posted,
Dose the original number show when calling or texting ??
It may be a case of calling customers service ,,, again or
Poping in to store for the BT/EE store to swap the sim card yet again
Sorry
31-03-2022 06:46 AM
Hi, thanks for your answer. No, my new number shows up on calls and texts and works as expected.
I'll do that though, thank you.
31-03-2022 06:48 AM
True, it's more of an annoyance!!
It shows the original number on my phone, on the SIM card manager, and also on my contact details when I tap on my name at the top of the Contacts menu. It's almost like the change hasn't rolled out globally, if that makes sense?
31-03-2022 07:45 AM
@Karaokequeen Have you restarted the device?
31-03-2022 08:19 AM
Yeah, countless times. I've also tried removing and re-inserting the SIM.
31-03-2022 10:04 AM
