13-04-2025 01:57 AM - last edited on 13-04-2025 09:56 AM by Christopher_G
I am abroad and can not call my UK voicemail to check my voicemails. I do not have a pin as no one ever told me I need one abroad, and EE customer service is closed in the UK when I am awake. This is a Business phone. Are you MAD??? You offer a service to businesses. Well-aware business people travel, but I cannot access any tech help or anything when I am awake. My UK phone, which I pay 150 per month, also doesn't work. I cannot make or receive phone calls. What am I paying for??? This is wild. How can you not offer this tech help 24 hours, 7 days a week??? NORMAL in the USA. This is pathetic—poor customer service and not a business-friendly company.
13-04-2025 08:33 AM
EE's business help site has some specific advice on using voicemail abroad - https://business.ee.co.uk/help/ee-getting-started/voicemail/ - having a voicemail PIN is mentioned.
If you cannot make or receive calls, then the standard advice 're roaming would apply. Does your phone show a connection to a local network in your host country? Did you receive a welcome text message on first arrival?
If your underlying issue is that you don't have roaming enabled, and/or can't make calls - this would have a consequent effect on your ability to call voicemail, in the same way as it would affect your ability to call any number.
13-04-2025 08:10 AM
Hi @isso
Welcome to the community.
I'm really sorry to hear of your experience with this. You do need a PIN to access voicemails from abroad. If you speak with our business support team, they'll be able to try and get one set up for you.
The team are open 08:00 - 18:00, Monday - Sunday (UK time).
13-04-2025 08:33 AM
13-04-2025 09:38 AM
@isso : Did you receive a Welcome text upon arrival?
