not receiving OTP in Roaming
H3KTOR
hello
i hope you help me about this i was in uk before and now i come to iraq also i have traveled to iran too , in both countries i was unable to receive any OTP from whatsapp , instagram , facebook , telegram and any other apps
i tried many networks in 2g, 3g, 4g but its not work
alsoi asked chatgpt for any SMSC number , which i get +44********** and i get this as EE backup SMSC number +44**********
i changed this too but i didnot get any OTP
Note that please i receive EE sms like below i just dont receive any OTP
Welcome to Iraq. Calls cost £1.80/min to make and £1.80/min to receive and texts 60p each. Picture messages cost 48p.
Using data is worry free, click add-on.ee.co.uk for FREE to get more information or choose a set amount of data and if it runs out we'll check if you want more, so you always know what you're spending.
Your current balance is £11.00
Call +447953966250 for Customer Services & 112 in case of emergency. Have a good  trip!
[Mod edit - removed mobile number. Please do not post personal details in the community. Thanks!]
Northerner
Hi @H3KTOR
Have you checked these are acceptable apps in the country you're visiting.
Was the PAYG SIM activated and used in the UK.
as i researched , ee support iraq for roaming in korek , asiacell and zain network
receiving otp messages are free , as i know , so there shouldn't be problem about this
and yes i was in uk before and i use my simcard very well , but now I'm stucked here because i can't receive OTP messages
ChatGPT is totally incorrect with the advice it's given you (I'm not surprised!). The SMSC is only relevant for sending SMS, and EE's only SMSC number is +44 7958879879
Can you receive person-to-person texts? Try texting yourself if you're not sure.
Have you tried manually swapping between local networks, and are the symptoms the same on each one?
Can you make calls & texts?
Had you used that PAYG SIM for making calls or texts in UK before going abroad? To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
