Using mobile whist abraod
Profile closed
Not applicable
Can’t make calls to UK using my mobile from Portugal. Recently switched from BT to EE. BT had no problem calling UK from Portugal…all within my monthly plan..no extra charges. I thought I had the Sa,e plan with EE…that’s what I was told. Not prepared to pay extra charges. What to do?
@Profile closed  Did you text ROAMING to 150 before you left the UK ?  Have you tried just restarting the device?  Have you tried manually searching for a different network to join ?  Only certain plans have roaming included without the need to purchase an add on, but the ability to roam still requires you to have roaming enabled on the account by texting ROAMING to 150.
Do you mean you have a PAYG Saver plan with EE? If so, did you switch from BT to EE while you were abroad? If so,  you can't now use it until you return to UK. EE PAYG SIMs need 1st activating on EE's home UK network before they can be used abroad.
Matt_124
I believe they mean they thought they had the 'Same' as they had with BT in reference to roaming charges.
@Matt_124 : Yes, I would've thought the same if it didn't have a Cap 'S'.
