13-10-2024 04:40 PM
Hello I'm now in Europe and my network doesn't work? How can I use it?
15-10-2024 05:06 PM
@Power345345 wrote:
first time use and its payasyogo
also sim card place in phone out of uk first time, should I go back to UK to activate sim? Thanks
All new PAYG SIMs need to be activated on EE's UK network before they will work abroad. If you haven't done so and are now abroad, the SIM will need to be used in the UK first.
13-10-2024 04:43 PM - edited 13-10-2024 04:43 PM
@Power345345 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
15-10-2024 04:53 PM
15-10-2024 05:06 PM
