Unable to make calls from US
Woddeh
Hi all,
As the title suggests, I'm currently in the US and unable to make calls. I've tried all the usual suspects including changing provider (only have access to T-Mobile where I am) and spending caps, roaming is enabled and WiFi calling has been enabled and disabled for various tests, but no success.
My phone (Pixel 8 Pro) seems to struggle to force VoLTE as there isn't an immediately obvious setting for this, I don't have access to any other phones for UK calls and the chat bot has been wholly unhelpful.
Cheers
Woddeh
UPDATE:
I contacted EE shortly after this post, they restarted my roaming services and I was able to make calls again. To anyone who has this similar problem, I would suggest reaching out to EE as your first port of call after doing the basics.
To everyone who made comments on this post, thank you for your kind assistance.
7 REPLIES 7
Howdy,
I did receive the text, I went on to text ROAMING to 150 once I'd landed but not ahead of time.
I'm a contract customer with the Roam Abroad pass (currently covers the US, I spoke to an EE agent about it recently). I've tried both non-automatic and automatic network selection, but they both only permit access to T-Mobile in my experience thus far.
Unfortunately, rebooting didn't work.
Cheers!
Ali_A
Hi @Woddeh
As you're using a Google Pixel, can you try resetting your network settings?
The steps to do this should be - open the Settings app, navigate to "System," then "Reset options," and select "Reset mobile network settings".
Please be sure to reset the network settings only!
Once you have done this, you may need to switch your device off for a minute or two.
Let us know how you get on.
Ali
Just leave EE network…..this is a rip off.  My son is in USA and lost his ability to make calls or use phone without Wi-Fi despite me paying for data roaming and 100mb of data.   That’s all gone now.    No he can’t travel home to activate his SIM before he goes because he’s at university over there…. So EE have changed our contract that is now useless but we are being charged for data we can no longer access.  Rip off.
‘’simple solution we all leave EE and he buys a sim from USA phone shop and we move on
Ali_A
Hi @Meckers75
Is your son on Pay monthly or Pay as you go?
Ali
Woddeh
UPDATE:
Katie_J
Thanks for coming back and letting us know @Woddeh
Katie
