Sms abroad
Baseltw
Hey so I’m abroad and they got no EE signal at all so I dont get sms messages or able to call and I really need this sms I should get on my EE number I tried contacting customer service but again I don’t have service and wifi calling doesn’t work
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
