Signal issues
Gman4815
Just landed in Türkiye and I can’t get a reception at all and just for a change the app is down. I have 4 flat bars an me no messages underneath it no texts upon landing nothing
@Gman4815 : Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto.
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
