on 26-08-2024 01:34 PM
*SOS error while roaming in the US*
Hi - I am currently roaming in the US and can’t seem to connect to any cellular network. I have the SOS error constantly. I’ve already purchased a roaming pass before traveling.
And when I ask for help on the app it’s useless and I can’t text 150 since I don’t have cellular network connection! I’ve already gone through and selected data roaming, automatic network selection, etc. Can anyone help me please?
Many thanks in advance!
on 26-08-2024 01:44 PM
on 26-08-2024 02:49 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
