Roaming
Beckymeakin
My roaming was off when I left england, I've switched it on now bit won't work
Schockwave
Hello @Beckymeakin ,
Welcome to the community,
Are you on monthly contract/ If so, did you enable roaming before leaving the UK? If not you will have to ring customer service to get them to do this. You can do this by using Skype for free, see my signature.
Have you tried rebooting your phone to see if that works, so long as you have roaming enabled on your account?
If on pay as you go, roaming is automatically enabled, and you will need credit to use it.
Northerner
Hi @Beckymeakin
Is roaming activated on tour account.
On what basis do you say "I've switched it on" - what do you think you've done to enable roaming?
Katie_J
Hello @Beckymeakin.
When you arrived at your destination did you receive a welcome text from EE?
Are you connected to a local network?
Katie
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
