Roaming in India
malinipradeep
Hi
i I am in India and there is no signal. How do I check if my roaming is active? I also bought an add-on roaming pass. Still no signal. I am unable to call the customer care. Please help!
tq
ms
@malinipradeep : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
I did not activate roaming.
how to call the free phone, please?
Use Skype over WiFi as I suggest.
