Roaming data
baldi87
Valued Contributor
Valued Contributor
Currently I am abroad , my sim only plan comes with unlimited data. Bought Roam abroad pass and I know that I can use up to 50gb per billing cycle , but how can I track how much data  been used? It will not show on my app. Any ideas? Apart from tracking it on my phone. Which may be not most accurate.
7 REPLIES 7
Either use your phone's data counter, or text BALANCE to 150
You can't! On an unlimited data plan EE will not tell you your usage.
Chris_S
Hi @baldi87 When your phone reaches the allowance, it will stop you from using your data, so you'll not get charged any extra, you'll then have the option to then move to £2.47 per day usage.
I don't think so, @Chris_S , you will be surcharged for data @ 0.36p/MB.
Even in EU with the £2.47 per day usage there is still the FUP of 50GB. I dunno why you mentioned it; you dunno that the OP is in EU.
Chris_S
@XRaySpeX Good point, I should have asked if @baldi87 is in the EU or not, Just relaying info that I managed to find here here
baldi87
Valued Contributor
Valued Contributor
I am currently in Poland, and have purchased Roam Abroad Pass as it works out cheaper for me than 2.47 daily charge. But still can't track my data usage.
As I said, you won't be able to.
