31-03-2025 04:22 AM
If you are an EE customer and going to Australia BEWARE.
Despite signing up to a new pay monthly account, signing up to roaming before I left and paying the extortionate roaming pass fee of £26 for 7 days I now find I cannot make calls in Australia.
I have been to Apple Store and Optus store as EE use Optus here in Brisbane.
neither of them could get the calls to work.
when I try to sort it out I am advised to call EE but I cannot make calls. EE help is the worst I have ever tried to work with. It’s designed to make you give up.
31-03-2025 08:00 AM
31-03-2025 11:11 AM
31-03-2025 12:08 PM
Some pertinent points are in your second post, that you didn't mention originally - hence my advice did not allow for them.
Neither Apple or Optus personnel are in any position to advise on whether your phone is setup for roaming - they can check phone settings which will include "data roaming" menu options, but they have no access to your EE account to check for overall roaming permissions.
You didn't mention that texts & mobile data are working, these prove the roaming ability. If calls are not working, that lends to either a spend cap issue or - more likely - an international call bar active.
31-03-2025 05:31 PM - edited 31-03-2025 05:32 PM
@bristolian ….. I’m just sitting on the sidelines of this …. I’m sure what you say is most likely correct, however don’t you think it would make sense that if EE sell a customer a roaming pass allowing use of their plan minutes, texts and data then they should be able to use it without having to get a crystal ball out to second guess what other hurdles may lay in the way. If a customer has something preventing the pass being used then the EE system should tell them this before the customer pays for the pass, rather than take the money and leave a customer struggling to find a solution from abroad.
02-04-2025 03:27 AM
02-04-2025 08:14 AM
I completely agree! The roaming facility & international call bar slips through the net far too often.
There's good reasons why some users may still want a spend cap inplace.
06-04-2025 01:32 AM
06-04-2025 11:44 AM
Hi @h_shewan,
I am sorry you are still having issues with calls in Australia I understand that will be frustrating. Just checking have you tried to connect to all other available roaming networks as suggested earlier and were they all the same?
What happens when you try and make a call to +44 (0)7953 966 150? Do you get a recorded message or anything like that?
There may be something account based that is preventing the calls as mentioned, but we have no account access through these forums to check I am sorry, it is something only one of our guides would be able to confirm.
Alex
17-04-2025 10:51 PM
