OTP - Tortology
Twinkleboat
I am overseas and trying to go to APP to get Roaming.
BUT it is giving me a OTP to my phone in UK.
BUt I am not in the UK. I am overseas AND my phone is not YET working.
Any ideas how I get out of this silly loop. It would be nice if EE gave an option to get OTP by email OR phone!
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
@Twinkleboat  To enable roaming on a device you text ROAMING to 150 while still within the UK but as your out of the UK you’ll need to call customer support from a different device, you can not enable roaming from within your online account or via the EE app.
