Mobile data
ClaresyC
I'm in Majorca and have 20G data and have signed up for daily roaming allowance, my family can all use their mobile data but I can't access mine at all. My phone keeps telling me I might not have enough data. I can receive texts but cannot reply. Also the app won't work on my phone but will work on my husband's. I'm the one who has access to all accounts so I can't even search problems on there.
@ClaresyC : Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Ali_A
Hi @ClaresyC
Welcome to the EE Community
Some things to check -
While you have the daily allowance set up, do you have the actual EU roaming access activated to allow use while abroad?
Do you have data roaming setting switched on?
Are you able to access the internet/app if you are connected to WIFI?
Ali
If you can receive texts, you have a mobile network connection and thus roaming is enabled.
 Can you be more specific on what "my phone keeps telling me I might not have enough data" means? How is your phone telling you this, and what exactly is it saying?
Do you have a spend cap set?
