How to stop roaming back in the UK
elenatoo
Valued Contributor
Valued Contributor
Hi.
I used roaming in Spain for a week. Yesterday  I came back home to the UK. Should I notify EE that I don't need roaming any more? How to stop roaming in the UK?
Thank you
@elenatoo : There's nowt to stop! You're not roaming when in UK.
Peter_W
Welcome to the Community, @elenatoo
As @XRaySpeX has mentioned, you don't need to do anything upon returning to the UK to end any roaming charges - this will stop automatically once you reconnect with our network.
If you were looking to amend or disable the ability to roam on your account though, you can do this by texting ROAM to 150, or also by giving our team a call 😊
Peter
elenatoo
Valued Contributor
Valued Contributor
Thanks a lot!
