HELP
Ashleighreid22
Hello I’m in Spain about to leave my apartment to return home and I have no internet and I urgently need it what do I do?
Northerner
Hi @Ashleighreid22
Are you on EE PAYG or pay monthly contract.
Have you tried restarting your device.
I’ve tried to do that and then the number it gives me and it’s all in Spanish
@Ashleighreid22 : Did you have it before you went to leave your apartment?
Can you make calls & texts?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
